DeeBo's avatar
DeeBo
Engine knocking
Our RV makes a loud knocking when all 3 of the following occur simultaneously, overdrive kicks in, engine fan system turns on and accelerator is pushed. Does anyone have an idea of what could be causing this? Thanks so much for any help.
  • How many miles on the engine. It may be a carbon build up in the heads and is causing pre-ignition. Premium fuel will help.
    Have the engine checked for proper timing and advance.
    Ken
  • 2003 Tiffin Allegro Engine is a Workhorse 8.1. Thanks!
  • Without more info, I'd add check the fan clutch and the water pump shaft for loose bearings. It would be helpful to break out whether this is engine spark knock...
  • A few more particulars are necessary.
    MAKE
    MOCDEL
    ENGINE |
    YEAR
    Without any more info the only thing I can say is try changing the KNOCK SENSOR if your rig has one. Most do.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
