BiggD's avatar
BiggD
Finally weighed the TV and TT together... ugh
I thought maybe you math geniuses could help me out with my questions?
TV = '12 Ram 1500, Hemi, 3.92 gears, 6800 GVWR, 1219 lb payload, GAWR 3900 lbs (front and rear), GCWR 15,500
TT = '13 Salem 26TBUD 815 lb hitch weight and 5730 dry weight (dealer specs)
Tow Vehicle (no trailer)
TV weight 6140, GAWR Front 3540, GAWR Rear 2600
Payload = GVWR 6800 - TV weight 6140 = 660 of payload of additional payload
Travel Trailer weighed while connected to TV
TT weight 6180
TV and TT combined
TV weight 7840 (GAWR Front 3500, GAWR Rear 4340) + TT weight 6180 = GCWR 14,020
Payload = GVWR 6800 - TV weight (with TT) 7840 = -1040 of payload
Hitch weight is 815 and the equalizer hitch is 88 lbs = 903 lbs added to the rear axles. GAWR Rear 2600 + Hitch weight 815 lbs + Equalizer weight 88 lbs = 3503 lbs a 837 lb difference from 4340.
If hitch weight is 10-12% of trailer weight, to get 815 lbs it is approx 13.2% of 6180 lbs. Does this seem correct?
If my calculations are correct I am alright except for the overloaded payload. I thought the Equalizer would apply more weight to the front of the vehicle and also to the TT axles therefore reducing the weight on the rear axles. Since the front axle weight was reduced by 40 lbs do I have the Equalizer hitch setup wrong? Do I need to adjust it to distribute the weight a little more evenly?
Please don't post that I don't have any concern for my family's safety or tell me to upgrade to a 2500 or 3500 series. I am making the best I can with what I have and most of our trips are within an hour of driving.
You can tell me if my calculations are completely wrong :S
Thanks for any input!
Looking for advice before your next adventure? Look no further.25,143 PostsLatest Activity: Jun 27, 2025
