greycode
Sep 11, 2017Explorer
TurnThePage wrote:
Not sure if this would be applicable for you or not. I sealed my fresh water tank output connection, then routed a new hose from the fresh water drain to the water pump. I just used an elbow, Tee, cutoff valve (for draining), some hose and clamps.
I believe this could work for me as well. I'd need to do some investigation as to where a couple of drains that I have are routed to. My main drain is right next to the fitting and connected with a gate valve. Along the same vein, I might be able to seal/patch this fitting and install a new one next to it.?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
