Gjac
Apr 08, 2014Explorer III
There are many options on the "best way" to replace the battery terminals. What I do is remove the broken/corroded terminal replace it with one that fits the wire size of the cable. Clean/strip the cable to be free or corrosion then using a set of vise grips and propane torch solder the cable to the terminal then use shrink tape to prevent the corrosion from getting to the cable. I assume you do not have or can borrow a hyd battery crimper and die set.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
