milesbuiltbymil's avatar
Dec 04, 2017
Powerhouse generator battery replacement
My five year old Powerhouse PH2100pri portable generator has been reasonably reliable, but sure wish I had sprung for the Honda. No one will service it, so I do it myself, and so far have kept it functional. I now need to replace the OEM battery (Leoch DJW12-5.0), which has been tough to locate, and I'd guess cost more than it should. The space available in the generator housing is just big enough for the OEM battery, so a substitute isn't likely an option. Is there any reason that I can't skip the battery in the generator and just run cables from my truck or trailer batteries to the generator leads to active the starter? The OEM battery is 5amps, so my concern is that I'd cause damage by giving the starter too many amps.
Thanks in advance for any input.
Miles
  • SidecarFlip wrote:
    You can get a replacement battery at Harbor Freight. It's the same battery they use in their new electric start inverter.
    This and don't forget to take the 20% coupon like I did. :S
  • Hi,
    I modified my Yamaha genny to allow me to boost it. I've had occasion to do so in the last 2 weeks. I used a boost type battery charger powered from my inverter.
    Another option would be to add a device similar to a Trik-L-Start.
  • What is to 'service' anyway? Oil change, clean the foam air filter, replace the plug every 5 years run descent gas with stabilizer and you are good to go. Even a valve adjustment is cake. The valve cover is 'O' ringed and the clearances are in your owners manual and it has screw type adjusters. Box wrench and flat blade screwdriver and 5 minutes.
    I should be in small engine repair and service, I'd make a killing,
  • You can get a replacement battery at Harbor Freight. It's the same battery they use in their new electric start inverter.
  • Amps are pulled. Volts are pushed. No worries.
    YOU can't give a device "too many amps".
    You control the input VOLTAGE and the device draws what it needs.
    As for "jumping" to start the gen, that might work but it might need the battery to KEEP running......or to excite the generator for it to work.
    Have you tried a battery specialty store ?
    I think they can get pretty much anything......given a little time and some $$$.
  • I have a PH2100pri that has worked very well for me ,BUT. If you leave the switch for remote start on for more then a few days the battery goes dead. Either start it every day or start it with a rope. Now that I have a class a with generator I only use he PH2100pri at home an I jump it with a car battery every time.
  • DrewE's avatar
    DrewE
    Explorer III
    As Mex said, assuming it's a 12V battery, any 12V battery will work fine. The amperage is determined by the voltage and the impedance of the starter, not by the size of the battery (well, assuming the battery isn't so small that the voltage sags excessively while cranking).
    You probably can find a replacement battery of the same size elsewhere, though, even if it's a different brand. Maybe something like this would do the trick.
  • If the battery is 12-volts, you could jump start it with a 12 volt battery the size of Staten Island, and the generator wouldn't know a thing was different.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
