BarneyS wrote:
Mike Up wrote:
So how is the new Blue Ox Sway Pro system different than the standard Reese Trunnion system without the Dual cam sway control, besides the Blue Ox rotary chain latches.
I can see the downward tilt force of the Blue Ox sway, but this should also be happening in standard trunnion systems with downward head tilt without any additional sway control hardware.
I just don't see how the Blue Ox 'new' Sway Pro head is anything different than a standard trunnion head but without any adjustable tilt.
Thanks
I agree. I still fail to see how the system provides sway control other than the friction between the bar sockets and the hitch head (similar to the Equal-izer). I don't see the chains playing any part at all in sway control. The tilt of the hitch head/chain tension during a turn or sway would be the same as a normal WD hitch so I don't see any difference there either.
Barney
Hi Guys,
The computer simulation model found on their site
Blue OX site at minute 2 of the 6:02' U tube attempts to explain how their anti away control works.
This snap shot from that video is part of the explanation
See the angle of the trunnion socket pivot bolts. They are counting on that angle of the trunnion socket pivot bolt. And since you cannot adjust the head tilt, it will be there.
See the cross section of the WD bar. The new WD bars are thin in the long direction with a fine taper in thickness all the way up to the trunnion socket. The WD bar is full width just about from the chain to the trunnion socket. The WD bar will flex (bow) much more easily across the long thin section than the left to right as viewed from the top.
I "think" (do not know for sure), they are counting on the fact that when the TT and TV are far enough off center, (TV at an angle to the TT) the WD bar force will increase and "help" guide the TT to track back on center. The shape of these WD bars are different than most traditional WD bars and will flex different. The angle of the trunnion pivot bolt and the WD bar force create a force in the direction to "help" guide the TT to track back to center.
I can see the concept helping to aide in this high degree off center effect, and I can see the Blue Ox WD bar profile flexing better than the conventional WD hitch WD bar, however... I see it as a reaction verses a prevention method of anti sway control. An unknown is, how much off center angle between the TV and the TT is needed to be effective?
They state that their chain brackets "eliminate sway" at the minute 3:39' mark in the video. I believe that to be an incorrect statement or a marketing promo mix up. I do agree their longer support chain bracket "limits" chain swing. However if someone is using a high rated WD bar in relation to the loaded TW, the chain will be long and still be able to swing more than it would on the more matched WD bar.
The instructions here:
http://swaypro.com/Uploads/Docs/BXW0550,0750,1000,1500.pdf state a level TV is a method of proper WD. This one size fits all statement does not apply well to the large set of combinations of TV's. They are also going by 1 to 2" of hitch connection drop as a method of measurement of WD. I "believe" they are trying to simplify the setup verses what WD is suppose to be doing on the TV. I myself would not use that method as there are other variables in the TV that can make their stated end result not be correct.
In the instructions, under troubleshooting it talks about what to adjust for excessive sway. They tell you to properly balance the TT. I and many others 110% agree with this as it is the underlying foundation of proper trailer setup. If the TT is balanced properly it should not be swaying.
As I mentioned before, the quality of craftsmanship is very good. The WD bars and trunnion sockets have some very nice features. The rotary chain brackets offer a different approach and helps on some TT's with LP tank mounting issues. I do prefer their prior generation adjustable hitch head to allow for finer resolution of the WD. The big question comes back to, how effective is the anti sway control as compared the ultra high friction types of anti sway control?
If an RV'er has a well matched stiff suspension, stiff tire flex TV and a well balanced TT for low anti-sway characteristics, well how much force resistance do you need from a anti-sway WD hitch when towing on the ball some 48 to 65" behind the TV rear axle? Reese, Equalizer,Husky,Blue Ox, EAZ lift etc do not put some kind of rating on anti sway control. With all the TT & TV combinations and variables in the setup, how can they? So, well, you are left to figure it our for yourself.
It would be really good if one of their technical staff could help explain how they came to the conclusions they did and what testing helped them make those statements. Their latest video is the most we have had from them on the web.
Hope this helps
John
