belfert
Oct 05, 2015Explorer
westend wrote:
It takes a lot of miles to run the tread off until belts are exposed...just saying. I think this situation is aggravated by the TPMS systems. An owner doesn't have to look at the tires, just believe that the TPMS is going to save your bacon.
In this case it did but there is little to go on to diagnose why the tire failed or when the unusual wear started. I'd bet a buck that any new tire mounted in that position will experience the same wear.
It wasn't worn to the belts. The large hole in the tire exposed the belts. I took the tire back to Walmart and they said it had about half the tread left at best.
The trailer gets tons of maintenance done to it. The bearings are checked every year before going on a big trip. Before the next big trip the hub will be torn down to be sure nothing is going on that could be causing tire issues.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
