kellertx5er
Oct 06, 2015Explorer
myredracer wrote:
Another ST tire quality thread. Oh joy...
Without knowing the true and accurate history of external damage, towing under-inflated, towing in excess of 65 mph, etc, which is essentially impossible, there is no point in blaming the brand or place of manufacture. One problem is, when someone buys an RV with ST tires on it, nobody explains to them how they really need to be treated and it may not be until they go onto an RV forum that they find out.
AMEN! x3
I would really love to know how many tires fail when used only within their design ratings. Do all of the Marathon haters drive 65 mph or less? And please don't try to claim that GY rates them for higher speeds if you increase the pressure, they DON'T. From PSB #2014-01:
"Goodyear Marathon Special Trailer tires, with the “ST” size designation, are speed rated at 65 MPH (105 km/h) under normal inflation and load conditions.
• This speed rating is based on Tire and Rim Association loads and inflation pressures for ST trailer tires without a service description for speeds up through 65 mph. (ref: TRA 2013 Year Book)
• If Goodyear tires, with the ST designation, are used at speeds between 66 and 75 mph (106 km/h and 120 km/h), we recommend the cold inflation pressure be increased by 10 psi (70 kPa) above the recommended pressure based on the trailer placard for normal inflation and load conditions."
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
