cougar28's avatar
cougar28
House batteries (has 2) durning storage.
On our new 5er it has a battery disconnect switch but doesn't shut every thing off. Just had a RV carport built but to far away from ac power to plug in. So thinking maybe a solar charger to keep the batteries charged
plus the demand. Or another disconnect switch directly off the battery to totally disconnect them and maybe a small solar charger.I don't want to pull the batteries because I do check things every 3 or 4 weeks inside and out during storage just making sure there's no problems with anything. What do you do? Your thoughts?
  • How far away from the nearest outlet IS it ?
    I suggest that a long extension cord and a small "Battery Tender", or equivalent, maintenance charger would be best. Probably would keep them charged OK if connected only a day or two a month.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I like the solar charger idea. say a 100 watt panel should handle most if not all. monitor the voltage (battery) and if you see it start to drop go to 200 watts of panel but I think 100 will do it. DO not forget a good charge controller for a 100 watt panel you need a 10 amp controller minimum. I'd not go bigger than 20 amp for the controller or the loss in the box will be too great. MPPT is best.
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
