The_Texan
Mar 24, 2013Explorer
in5r wrote:And that is the problem in an RV, that is insulated with high density foam. I have yet to find a molly that is both short enough and will expand properly, into the high density insulation on our RV.
One piece of advice if using the hollow type wall anchor "molly bolt" take into consideration the thickness of the luan panel it will be clamping to. It needs to fully clamp down on both sides of the panel.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
