jhatton
Mar 25, 2013Explorer
I have been drilling the hole bigger with a 3/4 forstner bit (carefully) to the depth of the back wall but not into the back wall (slightly longer than the screw you removed usually) then installing a 3/4 dowel into the hole using a polyurethane glue. The polyurethane glue will expand so be sure you tape the dowel so it does not push back out.. then using a flush cut saw clean off the bit of dowel sticking out, drill and re screw. haven't had one fail on anything yet.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
