relaxin
Sep 13, 2013Explorer
JJBIRISH wrote:
I to use the toothpick trick, but that isn’t the answer for your promlem…
Screws will never hold well in thin wood paneling… you need to install one of the the types of wall mollies available to hold especially while bouncing down the highways…
I have used the one in the middle a few times and they work great, toggles are good so long as whats being held has a flat area the size of the toggle when using on thin paneling, but the hole is far bigger than the screw and if there is a possibility of the item moving it eventually will.
I have a few of these in my toolbox in the trailer just in case
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
