AO_hitech
Sep 16, 2013Explorer
rk911 wrote:donn0128 wrote:
Down and dirty simple fix? Take a tooth pick and some Elmer's glue. Apply a small amount of glue to the tooth pick and shove it in the hole. Once the glue is dry, replace the screw. Good for nearly ever. BTW this is a great fix for particle board holes too.
been using this trick for a while now and donn's right...the repaired hole will hold for a long, long time. but, depending on the size of the hole, you may need more than one toothpick.
I can't tell you how many stripped holes I've fixed that way. I don't think I have ever had to do the repair twice. :)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
