Sprink-Fitter
Nov 26, 2014Explorer
MFL wrote:Water-Bug wrote:
I know that the answer depends on the current draw of the RV, but am wondering if it would be safe to run the AC on a 100 ft 30 amp cable. The answer is probable to turn on the AC and measure the voltage drop at a plug, but buying a 75 foot cord just to find out could be an expensive experiment.
I think 30 amp RV chord uses 10 awg wire. At 100', you should have about 5 percent drop. So if you have 120+ at the pedestal, you should be fine, with nice clean connections between chords, and at post.
Jerry
Chord, the question is about electricity, not music.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
