- bigred1cavExplorer
tenbear wrote:
No problem switching between a large tank and a small one. I usually run my grill off a large tank and carry a couple of small green tanks in case I run out of gas in the large tank. I have switched a couple of times without a problem.
Thank you and all the others - tenbearExplorerNo problem switching between a large tank and a small one. I usually run my grill off a large tank and carry a couple of small green tanks in case I run out of gas in the large tank. I have switched a couple of times without a problem.
- DrewEExplorer III
bigred1cav wrote:
OK, I got the hose. How about pressure regulation? Is the pressure from the larger tank a problem?
Thanks for all the help
The pressure from a big tank is the same as from a little tank—namely, the vapor pressure of the propane. (Technically speaking, that's only true so assuming the temperature of the propane is the same. A small tank will cool down more quickly as the propane vaporizes, and will thus have a little lower pressure as time goes on than the larger tank, but that's of no practical consequence here. It does matter when trying to run a large appliance from a small tank.) - IAMICHABODExplorer IIINot at all,hook it up and enjoy.
- bigred1cavExplorerOK, I got the hose. How about pressure regulation? Is the pressure from the larger tank a problem?
Thanks for all the help - mowermechExplorer II
tenbear wrote:
While you are at it, you might consider an 11 pound tank. Same height but smaller diameter. It fits in places the 20# tank won't but is still refillable.
Or, the 5 pound (1 gallon) cylinder (the one I have); about the same diameter as a 20 pounder, but MUCH shorter! - tenbearExplorerWhile you are at it, you might consider an 11 pound tank. Same height but smaller diameter. It fits in places the 20# tank won't but is still refillable.
- nevadanickExplorerThey have the hose that you need in the bbq section at Home Depot.
- rhagfoExplorer III
- DtaylorExplorerI have seen them in Walmart
