Encore
11 years agoExplorer
Leaking Bottle
I have a radiator coolant surge bottle which is made of some type plastic. There is a brass fitting which screws into the top with a small tube connected to it with a clamp. The brass fitting has a small leak around the threads when the tank is hot and pressurized. I removed the fitting and put the white tape on the treads, but the leak persists. Is there a better method/sealant to seal this fitting?
