Flapper's avatar
Flapper
Inflating tires 10lbs over?
Sorry to do this, as I am sure it has been discussed a lot - but my searches came up dry...
So there was advice floating around on a past boat forum that properly inflated ST tires were rated for a max speed of 65 mph. For speeds higher, then the official word supposedly was to inflate by 10 lbs higher.
I see in an issue of Trailer Life that the same kind of advice was given. For my fifth, I did not see any inflation sticker, so I have always been inflating to the max on the sidewall. But, if I am going to be towing in the 65-70 mph range, should I be going 10 lbs over that? Or is the sidewall pressure the "never exceed" amount?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
