cbshoestring wrote:
Just because SOMEONE needs to say it:
For a violation of 1-4,000 pounds over the limit, the fine is 3 cents per pound. For violations of 4,001-10,000 pounds over the limit, the fine is $120 plus 12 cents per pound. For violations 10,001-15,000 pounds over the limit, the fine is $840, plus 16 cents per pound. For violations of 15,001-20,000 pounds over the limit, the fine is $1640, plus 20 cents per pound. For violations over 20,001 pounds over the limit, the fine is $2640, plus 30 cents per pound(EXAMPLE FROM STATE OF WASHINGTON).
YES folks, hauling over weight is illegal. This includes GAWR or GVWR. Chances are the above fines would only be imposed on a truck driver (As a fleet manager, I assure you they are), but the law in most states does not apply just to commercial vehicles...It even applies to you.
Please show me a statue that states GAWR and GVWR are legally binding.
In Idaho, and several other states I have looked up, there is NOTHING that holds me to the door sticker.
The limits that you can be fined for are exceeding tire limits or standard axle limits. If you are exceeding standard axle limits on a pickup then good on ya, it's 20K lbs/axle. Stay under your tire limits and you are DOT legal. Put 22.5" tires on a Ranger and load it up and you can probably get one of many tickets but they technically are not overloaded.
The only GAWR that must be obeyed, in Idaho, is a TAG axle. Otherwise AWR is a manufacturer number and not a DOT one.
While one should use caution if they exceed a door sticker I have yet to find where it's illegal.
Have the appropriate tires for the load, pay for your weight and use some common sense on loading... but mainly be safe. If unsure about the actual capabilities stick to what the mfgr has suggested.
