proxim2020 wrote:
AH64ID wrote:
Please show me a statue that states GAWR and GVWR are legally binding.
Texas laws are like that. You're restricted to your registered GVW and that weight is based off of the GVWR. Finding the info can be somewhat of an Easter egg hunt. Rather than post all the info here, I'll point to the chapters of the Transportation Code. Chapter 502 outlines how the registered GVW is determined. Chapter 623 outlines all of the restrictions and enforcement. Since the registered GVW and GVWR will match, residents essentially bound to their GVWR.
Now enforcement is another story. I've never heard of someone being pulled over to get checked. Even if in the rare chance you did get pulled over and it's determined that you're overweight, the inspecting officer can just request that you unload the excess weight to proceed. Officers here normally aren't interested in non commercial operators unless it's some really dangerous situation. They'd rather stick to big rigs since they are cash cows. Overloading, logbook violations, safety equipment violations, etc can fill the coffers pretty quickly.
Not the first time someone has said Texas laws do this, and not the first time that CH502 and CH623 have been referenced, but they do NOT state that GVWR or GAWR are part of the limits. The only time GVWR and GAWR are discussed is in definitions, that's it. In fact neither 502 nor 623 even discuss weight limits.
502 does not state that GVWR is used to register a vehicle, it simply says that it may be used. "The weight, net weight, or gross weight of a vehicle, as determined by the
department, is the correct weight for registration purposes,
regardless of any other purported weight of the vehicle."
623 actually deals with overweight permitting, it's 621 that deals with weight for normal operation.
For 623 to even apply you have to be registered at the max weight allowed by 621.101, which is 20K lbs an axle or tire limits.
The terms manufacturer, GVWR, nor GAWR are located anywhere in CH621.
I'm sure someone will read this who has a registration in Texas for more than door sticker weight.
My Idaho registration is good to 26K lbs, as long as I don't exceed 20K lbs per axle or tire limits (9K/axle).
