Y-Guy
Apr 11, 2022Moderator
I wanted to come back and update this thread. After a couple trips with the magnetic light I saw what willald was talking about. I decided to order the CoolTech JK Tow Harness Kit (not the deluxe though). I then ordered Hopkins 47043 Flex-Coil Nite Glow 7 Blade to 4 Round Adapter
Installation was pretty straight forward as far as running the wires, I did run the wire through the frame using a fish wire which made for a very clean looking install. That was the easy part. I setup as per the directions and hooked up *fail* it was like Christmas lights flashing but not the right ones. I ended up scrapping the wiring hook connections for the 4 pin on the Jeep side and instead matched those up to what the Motorhome was sending out - everything worked. I've since read that others had the same issue.
Bottom line is it works and it's seemless now. I will be selling the magnetic lights as a friend needs them when towing.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
