derh20's avatar
derh20
jensen air antenna quality
I am getting poor reception from my Jensen air antenna in my 2011 B+. A neighbor in my campsite, about 300 feet away with the same antenna, is also hot happy with the Jensen, but they do get about 5 channels more than we are. Any thoughts about the Jensen? Is there a way to increase reception? Is the bat wing better?
  • We have the Jensen "saucer" antenna and it suxs.
    I am an antenna "nut", I have studied antennas, designed antenna, taken advanced classes in antenna design (College 400 and 500 series) and published on antennas.
    When we got the rig and I started testing I was appalled. At home, with the new RV in the same location as the old RV (which has a Winngard Batwing) I got roughly 1/4 of the number of "stations".
    So I disconnected the antenna and connected random chunk of wire to the coax on the roof and got more stations.
    I then bought a "disc" antenna from Radio Shack and connected that. The new antenna was at roughly 6 ft high (vrs 13 ft for the one on the RV). I got the same number of "stations" as with the old RV.
    I couldn't install the regular batwing as the crank would be higher then I could reach.
    But yes, IMO almost any antenna will would better.
  • Before you go out and spend some $$$ you might spend a little time doing a thorough cleaning of all coax connections. They tend to get a little dirty, corroded, and loose fitting over time. Use some Q-tips and alcohol. You might want to tighten them just finger tight then use a 7/16 open end wrench just a TINY bit to make them tight.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 06, 2025
