pennysmom09's avatar
pennysmom09
Kudos to Coachnet.
Once again we needed help with a tire problem. We had a blowout on 95 just outside of
Florida today, we called Coachnet and they said help woul be there in 90 min. They arrived within the hour and changed the tire, with our spare. We will have other issues to deal with, (ruined fender, severed brake line) but we will continue on to our destination tomorrow, 130 miles, and hopefully the other tires will do the job. New tires before returning north. The body work and brake line is a complication however.
Now to research tires! Plus, we had to squeeze the damaged tire in the truck bed with the hitch, and a bicycle that was on a rack over the spare now has to ride inside the coach. The fun never ends!,
  • garmp wrote:
    So I take it that the both of you are CoachNet fans. We are looking at either CoachNet or FMCA and gathering pros & cons, but it appears that you two are both happy.
    Same here. Thanks for sharing your experience.
  • CoachNet sells tires also. Why not give them a call and see what they can do for you?
  • So I take it that the both of you are CoachNet fans. We are looking at either CoachNet or FMCA and gathering pros & cons, but it appears that you two are both happy.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: Oct 05, 2015
