isa
May 06, 2013Explorer
This is for Road Princess. I suggest you re-check the California DMV statutes with respect to a towed vehicle, viz:
California Vehicle Code Division 12 - Equipment of Vehicles
Chapter 3. Brakes
Article 2. Operation of Brakes
Control and Stopping Requirements
26454. (a) The service brakes of every motor vehicle or combination of vehicles shall be adequate to control the movement of and to stop and hold such vehicle or combination of vehicles under all conditions of loading on any grade on which it is operated.
(b) Every motor vehicle or combination of vehicles, at any time and under all conditions of loading, shall, upon application of the service brake, be capable of stopping from an initial speed of 20 miles per hour according to the following requirements:
Maximum Stopping Distance (feet)
(1) Any passenger vehicle 25
(2) Any single motor vehicle with a manufacturer's gross vehicle weight rating of less than 10,000 lbs. 30
(3) Any combination of vehicles consisting of a passenger vehicle or any motor vehicle with a manufacturer's gross vehicle weight rating of less than 10,000 lbs. in combination with any trailer, semitrailer or trailer coach 40
(4) Any single motor vehicle with a manufacturer's gross vehicle weight rating of 10,000 lbs. or more or any bus 40
(5) All other combinations of vehicles 50
* The bracketed information has been added editorially to meet accessibility requirements and is not part of statute.
Amended Ch. 443, Stats. 1965. Effective September 17, 1965.
Braking System: Towing Vehicles
26458. (a) The braking system on every motor vehicle used to tow another vehicle shall be so arranged that one control on the towing vehicle shall, when applied, operate all the service brakes on the power unit and combination of vehicles when either or both of the following conditions exist:
(1) The towing vehicle is required to be equipped with power brakes.
(2) The towed vehicle is required to be equipped with brakes and is equipped with power brakes.
(b) Subdivision (a) shall not be construed to prohibit motor vehicles from being equipped with an additional control to be used to operate the brakes on the trailer or trailers.
(c) Subdivision (a) does not apply to any of the following combinations of vehicles, if the combination of vehicles meets the stopping distance requirements of Section 26454:
(1) Vehicles engaged in driveaway-towaway operations.
(2) Disabled vehicles, while being towed.
(3) Towed motor vehicles.
(4) Trailers equipped with inertially controlled brakes which are designed to be applied automatically upon breakaway from the towing vehicle and which are capable of stopping and holding the trailer stationary for not less than 15 minutes.
Amended Ch. 121, Stats. 1991. Effective January 1, 1992.
Chapter 3. Brakes
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
