newrver327's avatar
newrver327
Max Pin Weight
I am one of the many who bought the tow vehicle before the 5th wheel rv. I have a 2009 duramax cc 2500 thinking I could then get anything I wanted,i know now "Not". So here's my question, what max pin weight would you suggest that I could be comfortable with? I know a 3500 would have been the way to go.
gcwr 22000 lbs.
gvwr 9200 lbs.
gw 6900 lbs. this is with a full tank
If I got it figured correctly that leaves me with 2300 lbs. for me my wife and 5th wheel hitch and pin weight, I know I will run out of load limit before I reach my rawr. So any rvers so went thru the same thing I would like some feedback.
  • Problem is the low GVWR (9200#)
    GVW of 6900# leaves you 2300# before reaching GVWR
    BUT
    how much weight do you have on rear axle? And how much is RAWR?
    Difference between the two is what you have for available payload.
    EX: RAWR---6084
    Weight ----2900
    Payload----3184 (3200)
    Subtract 5vr hitch weight, wife? and any stuff you have in truck (in door pockets,under seats, in bags etc)....400#
    Now you have 2800# of payload left
    12000# GVWR 5vr will have roughly a 2400# wet pin weight
    You are under RAWR-----under rear tire loading
    And you are over GVWR (6900 + 2400====9300)
    Those mfg. published max tow and combined tow numbers are magical marketing numbers based on a 'base model with 150# driver and 20# cargo'
    Real world is you run out of GVWR , RAWR and/or Rear Tire Load Rating LONG before you reach those magical tow numbers
    Take your truck fully loaded camp ready (You, fuel, wife, stuff) and go to a scale and get weighed.
    This will give you the real numbers......see how much weight you can add to rear axle/tires.
    Use 20% of 5vr GVWR as a wet pin weight
    Like in my example........12K 5vr
    You probably would be OK with a GVWR of 12K as you would not be towing trailer at GVWR.
    You will be over trucks GVWR.
  • I know a guy who bought a 1984 F-150 with a slim cargo rating, and 351" engine. He was looking at travel trailers with a 750 pound hitch weight, but ended up with a 24' Wilderness fifth wheel, I would guess it might have had a 1,500 pound pin weight, it was tiny compartment for sleeping up in the front (think camper cabover, not really the walk in style of today).
    Anyway it is possible to tow way more trailer than the truck is 'rated' for. Yes you could tow fine with a 2,000 pound hitch weight, and still not go anywhere close to the tire weight rating on your rear tires.
    What is your front and rear axle weight? My guess is with a 6,900 pound overall weight, that about 4,000 is on the front and 2,900 on the rear axle as it sits. That leaves around 2,500 more that you can safely add to the rear axle, however it will put you over the GVWR. Are you worried about warranty problems with a 7 year old truck? I would not be either. Basically it is similar to the 3500 truck that you should have bought. . .
    Anyway you will know better with the next pickup. . .
    Fred.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
