rshine's avatar
rshine
Must Motor home lights be on to tow a Jeep Cherokee?
We just purchased a 2015 Jeep Cherokee, Latitude. We took it in to have a new set of base plates installed, and to have it wired for towing behind our Winnie. The latter is, of course, already wired, and we are using our same Roadmaster Sterling tow bar and cables. All we needed were the new base plates. When I picked it up, I did not have the Motor home with me. The mechanic explained some things, then told me that with the new Jeep, I must tow it with the motor home headlights or running lights on.
When we got back I hooked the new install to the back of the motor home to test the lights. With motor home lights ON, there were no lights working on the Jeep! With the motor home lights OFF, the Jeep brake and signal lights worked in concert with the motor home.
Can any of you good folks help with this? And, can any of you affirm that the motor home lights must be on when towing the Jeep?
