Desert_Captain's avatar
Desert_Captain
Explorer III
Jan 28, 2020
Need help... can I 4 down tow a Mazda Miata???
I have an opportunity to purchase a nice little 2013 Miata and if I can make the 4 down towing equation work without having to reinvent the wheel and would like to go forward. I have seen lots of folks towing them 4 down but Blue Ox, Roadmaster and Trailer all have said no go. I spoke to a tech at the Mazda dealership and he said no problem with the 6 speech manual trans, just make sure you are in neutral and you're good to go?
If you or anyone you know tows a Miata please enlighten me as to what set up you/they have. Any tips pro or con would be appreciated. I have gone 6.5 years with no toad for 24' Nexus C but for a number of reason I am now open to pursuing this option. TIA.
:C
  • I dunno, it was what recalled, no guarantee as to the correctness, that's why I said IIRC. Because I could absolutely wrong. It's been some time back, that is why I hedged.
    It seemed like there was a pressure fed supply to the higher gears, and it was driven off the input from the engine. No engine drive meant no spinning pump.
    But like I said several years back and not positive about this. Could be a faulty memory, it's happened before.
  • fj12ryder wrote:
    I once checked on the Miata for towing, and IIRC, the six speed gearbox uses pressurized oil in the gearbox, so I'd do some serious checking before I towed it.
    Where does the pressure come from ? Not the engine.
  • Thanks for the timely replies. I know a lot of folks tow them but as noted above the towability is probably contingent upon the model year and trans. When I called Mazda they said their owners manual was a one size fits all publication. The prohibition therein on towing was referring to the models with an auto trans though it did not so state.
    Guess I will give up on this one... too bad it was a fun little car to drive and would tow like a dream being so sleek, low and light.
    Thanks again.
    :C
  • Owners manual says no. Miata forum says yes from several people with direct experience. It differs with 5 or 6 speed and year of manufacturing. Some suggest putting it in or on trailer.
    :C
    Sometimes the techs make mistakes on some pretty big issues.
  • Remco too says no to four down towing.
    http://www.remcotowing.com/Towing/Store.php
Looking for advice before your next adventure? Look no further.25,176 PostsLatest Activity: Nov 14, 2025
