_DJ_1's avatar
_DJ_1
Explorer II
May 25, 2018
Need suggestions to correct towing
Hi All, bought a gently used '16 F250 a few months ago. Towing my Arctic Fox is like trying to balance a marble on top of a balloon. It's horrible and semis all but blow me off the road. First off I've towed this same trailer with an '11 F250 and a '16 F250 diesel with zero problems. All 3 trucks have the same Super Hitch and Husky WD system, transferred over from each truck.
Anything over 50 mph is a constant battle with the steering wheel. It wants to wander without continuously correcting the wheel. Our freeway is posted at 80 mph but I only drive 60-65. When a semi passes me it wants to pull me in to the side of his cab. Then when the end of his trailer goes by it tries to blow me off in to the ditch.
I've tried just about every possible combination of spring bar tension and air bag pressure with no help. I'm thinking there is something wrong with the truck. It was used with 15K miles. Ford said no wrecks or problems. When this started I even paid $40 for a Car Fax which also showed no incidents.
Maybe a bad steering gear? First tuck I've had with a rear sway bar. I checked the build sheet for this truck and it is factory installed. Could it be contributing to the problem somehow?
I am at my wit's end!! Thanks for any suggestions. DJ
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
