bluepost's avatar
bluepost
New 30ft Trailer Towing Experience
Picked up our 2016 Sunset Trail 270BH from Manteca and towed it back to Reno using our 2014 Toyota Sequoia Platinum with 113t P rated Michelin LTX Defenders aired up to 42psi (max 44) and an Equalizer 4 point hitch. Tekonsha 90250 RF "wireless" brake controller.
Sticker weight was 5685. I stopped at the scales on the way home and had 50 lb Yamaha Generator in the back, full propane (+50 lbs), a single 27 series battery mounted (60? lbs), and about 100 lbs of "stuff"...tools etc, and a bit of water from the walk through.
Came out to 6020 lbs on the trailer with a 820lb tongue weight.
Truck was about 250 lbs under max weight with me inside. Leaving me 250 lbs for wife and 2 small kids, right below the limit.
The ride over Donner Pass (about 7100 ft) on I80 was no sweat. Never dropped below 3rd, 4th most of the time until high elevations, never had an issue holding 55mph. Never got above 62mph by own choice, and don't plan to (maybe one speed run to 75mph, max tire speed on trailer, for emergency purposes to test stability). Never got any sway, and the trailer was set up "okay". The dealer added an inch to the ball height for squat, but our truck has air suspension and it aired it up back to level putting the trailer just a bit high....not high enough anyone would notice, it looked good, but actually measuring and using a level it was a bit nose high. I have since adjusted the hitch height.
The dealer also "guessed" and the about of weight distribution, and was about one washer short. They never measured the front fender, and as set up it returned the fender to within about 1/4 of an inch. I'm going to continue to tinker a bit with that setup.
Once I got home I loaded our supplies into the bins and weighed each bin before putting it into the trailer. Also set up a tongue weight station and experimented with different water loads. Fresh tank definitely adds TW and the black must be mounted way back in the rear as it removes it.
As loaded I have the TW down to 730 lbs with 10 gallons (80 lbs) left in the black, and one propane tank stored under the rear bunks. Total trailer weight should be about 6150 lbs with blankets, some food, drinks, couple pots, full generator, tools etc. This give us an 11.8% tongue weight. Towing home I was at 13.6%
That TW gives our family of 4 (I'm 190 lbs, 130lb wife, two 50lb kids) about 530 lbs of useful load total, so with us that leaves 110lbs for "stuff" in the truck....as weighed at the scale. Don't plan on needing that "stuff" in the truck, we would just put it in the trailer, but we have some room.
Loaded with fresh water (830 TW) we will be right at or slightly (20lbs) over TW/Cargo load if we all go, so no full fresh water unless I can find some weight to add to the back.
Camped in our driveway last night, and plan on dry camping tonight at a state park close to home. Will only load about half water, but wife and kids are driving separately anyway so max cargo capacity isn't an issue on this trip. I just want to keep the TW light to see if there is a difference in towing.
Overall the Toyota Sequoia is awesome. I've done lots of other towing with it, but nothing of this length. The tow/haul mode works awesome by increasing the amount of throttle for a given distance of gas pedal travel, so you're not flooring and coming off the gas very much. Never floored it once, not even uphill in the mountains, maybe 1.5 inches of pedal travel max, most of the time it felt like I was inputting maybe 1/2-3/4 of an inch. My previous vehicle was a Denali XL, okay vehicle, and even with the longer wheel base of the Denali, the Toyota beats it hands down.
Coming down the hill the bad aerodynamics of the trailer behind me kept braking minimal. Started at the top of the grades at 50 mph (lots of 50mph curves coming down), downshifted a couple times, couple brake applications but MUCH better than coming down with my 5000lb boat with surge brakes.
9.8 MPG average over 180 miles starting at sea level, over the 7000ft pass and back to 5000ft in Reno. I was at 11.2 for the 90 min drive before I started heading uphill.
It never felt "squishy" to me, actually the opposite. A couple times I saw a bump or feature in the road that I thought would start it porpoising to the point I would wince, but hardly anything...in other vehicles, with shorter trailers, I would be worried about the hitch bouncing down and scraping, but not even close. Just nice and firm, but not harsh. Was it the wide axles on the trailer? The air suspension? The hitch? All three?
Overall happy with the setup.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 06, 2025
