- Ron_GratzExplorer
Brngrhd wrote:
Without WD, the entire 1000# tongue weight will be carried on your TV.
How does that all play out? If you have 1400lb payload and 1000lb tongue weight that leaves 400lbs for passengers and other "stuff" if your hitch moves 300lbs back onto the TT does that free up 300lbs of payload?
The WDH does not create load -- it only transfers loads among the axles.
If the WDH is adjusted to transfer 300# to the TT's axles, then the amount of load transferred to the TV is only700#.
That frees up 300# of TV payload.
Ron - BrngrhdExplorer
Taz 23 wrote:
OR BIGGER:W
LOL VERY true probably a 1ton SRW or even a DRW HA! - Taz_23Explorer
Brngrhd wrote:
OR BIGGER:Wskipnchar wrote:
No it will not increase your payload.
I didn't say increase my payload....ependydad wrote:
Payload is anything any were pushing down on the truck (passengers, cargo, tongue weight, etc.).
If you move weight to the TT physically moving the items or distributing weight via the WDH - you gain in your truck's payload.
That's what I was thinking, thank you!RinconVTR wrote:
There are some payload rating crazy people on here, and rating crazy people who fall into the category of the "weight police".
Payload ratings are not the end all number to be concerned about, because you see, not all payload affects the rear end like tongue weight.
But if you're close to the payload rating, you need to use a scale and make sure other numbers are within spec or at least near. Mainly rear axle weight rating and gross combined weight rating.
Thanks I'm going to have to scale this thing out in the spring. I know after reading/lurking on here if I post the combo most will tell me I need a 3/4 ton. - BrngrhdExplorer
Thanks I'm going to have to scale this thing out in the spring. I know after reading/lurking on here if I post the combo most will tell me I need a 3/4 ton. - RinconVTRExplorerThere are some payload rating crazy people on here, and rating crazy people who fall into the category of the "weight police".
But if you're close to the payload rating, you need to use a scale and make sure other numbers are within spec or at least near. Mainly rear axle weight rating and gross combined weight rating. - ependydadExplorerPayload is anything any were pushing down on the truck (passengers, cargo, tongue weight, etc.).
If you move weight to the TT physically moving the items or distributing weight via the WDH - you gain in your truck's payload. - skipncharExplorerNo it will not increase your payload.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 09, 2025
