calewjohnson's avatar
calewjohnson
Pesky Drip
I have a pesky drip in my basement, it is coming from the black item in the picture below. I gave it a 1/8 turn and it has mostly stopped, however, would like to replace it...maybe something non plastic.
What is it?
Cale
  • At least they're the better copper crimps and not the failure prone aluminum type.
  • I have to agree with Old Biscuit on this one. There's no other reason to have all of those fittings there otherwise; a 90-degree pex crimp and a longer piece of pex would have sufficed.
  • coolbreeze01 wrote:
    Looks like a coupler. I've had them come with cracks in brand new trailers due to poor workmanship. Properly installed, plastic fittings work well and are easy to replace.
    I know the cracks.....replacing the shower faucet because it is cracked....they rush to put stuff together and break things in the process. Luckily, I found the exact item on Amazon.
    Cale
  • Old-Biscuit wrote:
    Due to 'red' PEX pipe I suspect that is on the hot water system.
    What is the pipe coming from or going to??
    Look closely on black fitting---any directional arrows---indicating it is a 'check valve' which allows water to flow in only one direction.
    Again.....what is piping coming from/to?? Water heater? Faucets? ????
    All the piping is around the water heater. I can take another picture when I get home of the rest of the setup. It looks like the black item is on a loop by itself. I initially thought a one way check valve, but will verify a possible arrow this afternoon. Thanks.
    Cale
  • I would cut the business out and replace with sharkbite/gatorbite fittings and new pex as needed.
    Home Depot or Lowes has everything.
  • Looks like a coupler. I've had them come with cracks in brand new trailers due to poor workmanship. Properly installed, plastic fittings work well and are easy to replace.
  • Due to 'red' PEX pipe I suspect that is on the hot water system.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
