- run100Explorer II
Lynnmor wrote:
Acetone will melt some plastics instantly, be careful with using that chemical.
Thanks for the pointer. If the need comes up again, it will be used sparingly and with caution. - car2900Explorer
bradnailer wrote:
If you have an oil jobber handy, they sometimes have Varsol. I keep a couple of gallons on hand all the time. It will remove pine tar, road oil and most other stuff and is safe on paint. Elstwise, WD-40.
Varsol fluids are traditional aliphatic solvents that are also known as mineral spirits or white spirits. I think ExxonMobile has the trade mark. I think the carrier solvent in WD-40 is mineral spirits. You don't have to go to a oil jobber for mineral spirits, in any Home Depot, Lowes, Ace, even Wally World, etc. I sold the stuff for 30 years. When I retired I stocked up on a few gallons of OMS (Odorless Mineral Spirits) which is the more refined version of regular mineral spirits that does not have as much of a petroleum smell. Mineral Spirits is not a very aggressive solvent and it would take a little work to get it to remove pine sap. - w4phjExplorerI used mineral spirits.
My side grinder was too hard on the paint. - LynnmorExplorer II
run100 wrote:
Just had to deal with some serious sap on fiberglass and also the ladder. I started with the ladder and tried everything imaginable with no luck. I'm thinking with temps around 110-degrees, it becomes a permanently glazed surface.
Then, several people suggested acetone. Man, that stuff worked amazingly well! I barely even touched the sap on the ladder and it came right off. I also used it on the fiberglass and had the same results, with no damage (afterwards, I washed the areas thoroughly with soapy water).
Acetone will melt some plastics instantly, be careful with using that chemical. - run100Explorer IIJust had to deal with some serious sap on fiberglass and also the ladder. I started with the ladder and tried everything imaginable with no luck. I'm thinking with temps around 110-degrees, it becomes a permanently glazed surface.
Then, several people suggested acetone. Man, that stuff worked amazingly well! I barely even touched the sap on the ladder and it came right off. I also used it on the fiberglass and had the same results, with no damage (afterwards, I washed the areas thoroughly with soapy water). - 1rickwExplorer IIWe had a brand new tow car out the first week we bought it. We were camped in some pine trees that were infected with Pine Beetles. I used Mayonnaise. Took it all off. And the mayo just happened to be in my Fridge, and I could also use it for my sandwich.
- KurbennettExplorer IIOk, tried both hand sanitizer and rubbing alcohol. Both worked well but the rubbing alcohol seemed to do it quicker. Thanks all for the suggestions.
- hook47ExplorerNon-gritty hand cleaner such as GoJo. Also good to remove sap from dog's fur.
- Grit_dogTrailblazer
mikey98e wrote:
I was very careful and removed most of the sap from my truck with a single edge razor blade. Then I used alcohol.
-mike
That's what I call having ALOT of extra time on your hands!
The tarminator stuff works well on sap. It WILL permanently stain tail light lenses and black plastic trim though. - Paleo_RonExplorer III've used mineral spirits (sort of like turpentine) on my windshield to good effect. If using it on the painted portion of yout truck or on fiberglass, test a small area first.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
