- 1775ExplorerI removed dried pine sap with tar/bug remover. It came right off and did no damage to the finish.
- mr__edExplorer
Clay L wrote:
Isopropyl alcohol will dissolve it even when dried. I found that daubing it on rather than rubbing it worked best. Afterwards you will need to wash the residue off with detergent and water.
X2. I've used rubbing alcohol with great success (try to obtain it with the highest alcohol content, something like 90+ percent). The sap dissolves almost instantly and the alcohol doesn't appear to damage the surface. - Clay_LExplorerIsopropyl alcohol will dissolve it even when dried. I found that daubing it on rather than rubbing it worked best. Afterwards you will need to wash the residue off with detergent and water.
- bradnailerExplorerIf you have an oil jobber handy, they sometimes have Varsol. I keep a couple of gallons on hand all the time. It will remove pine tar, road oil and most other stuff and is safe on paint. Elstwise, WD-40.
- 12th_Man_FanExplorerLeave it alone until it dries and you can scrape it off with a fingernail.
- WD-40 or Goo Gone. Test on small area first.
- wittmebaExplorerI agree with WD40. But the process isnt just spray it on and wipe it all off.
My experience is it has to be removed by several layer/applications.
- Spray it on. Wipe it off (only some comes off).
- Repeat the process and eventually it will all come off.
Same process with road-tar. Several layer/applications. - wny_pat1ExplorerWD-40
- downtheroadExplorerI have used Tarminator...available at most auto parts outfits. Works great on tar, sap, road grease...will not harm paint.
Tarminator...LINK
- Francesca_KnowlExplorerIf I try the peanut butter idea, I'll bet the dog will volunteer to do the removal step...thanks!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
