- RCMAN46Explorer
Harvey51 wrote:
The level of the freshwater tank is a good indication of how much has gone into the waste tanks, unless you are bringing large quantities of liquid refreshments aboard.
My black tank level indicator has never worked.
I have never worried as my fresh water is less than my black and gray tanks. When I run out of fresh water I go to a dump and dump the tanks and refill the fresh water.
If at a campground using their water I go two days then add about three full toilets bowls in the black tank and dump. I have found the wife and I can go 4 plus days on the black tank. - pennysmom09ExplorerWe have had our fiver just one year. The sensors have never been accurate so we don't even use them. Experience has taught us when to empty....water in the shower, and looking into the toilet. Who needs sensors! :)
- dave17352Explorer II
sharker6 wrote:
Well you would really have to have a big bladder to get your feet wet using the stool. You should be able to notice when the slider is submerged!:W
Who needs a sensor? When your tank is full your feet get wet. Same with the grey tank and the shower. - sharker6ExplorerWho needs a sensor? When your tank is full your feet get wet. Same with the grey tank and the shower.
- bob_b1ExplorerI'd just ignore it. I've never filled the black tank in the last 11 years of ownership.
You'll need to dump that gray tank more than Twice before the black tank needs dumped.
If you still are still convinced that you need to fix the sensor, do a search on the GEO Method. There is a lot of good information on tank cleaning in his post. - mgirardoExplorerApparently I am one of the lucky 10% that doesn't have this problem, at least on a long term basis. Every once in a while when we are camping, if I don't rinse out the tank after dumping, the reading may not be correct. Probably some TP stuck on the sensor.
Fortunately our MH has a built in tank rinser which definitely works well. After 5 years, our currently empty black tank reads Empty on the sensor. I've never used anything to clean out the tank other than rinsing it with water.
-Michael - wa8yxmExplorer IIII would say 90% of all RVers have your problem.. I just ignore the beast.. My tanks have other ways of saying "DUMP, SOON".
There are 3 or 4 different sensor sets.
Standard is a row of nails, or equivlant of nails, these penetrat the tank wall, Just a metal rod inside the tank, if the rod is WET, then clearly the level is at least that high. The "Gauge" senses which rods are wet and shows the level.. The problem is that slime on the walls keeps them wet all the time.
HORST miricle probes are "1b" for this discussion, Same type of sensor but they have done a few things to make them less suspectable to slime.. Supposed to be good, I hope to install later this year.
There are Pneumatic sensors.. These measure pressure at the sensor point, if the pressure on both sides of the sensor is the same, It's not that full, If the pressure is higher INSIDE the tank, it is that full... I have only seen these in the instruction manual for my macerator toilet. alas the sensors were NOT installed.
In theory you could weigh the tank. Several companies make load cells that could do this.
SEE LEVEL sensors use some sort of electrical sensing to measure the level inside the tank.. People who have this type of sensor.. Say it works well.. The only problem is if the sensor falls off the tank These are the Cadillacs of the sensors. - wbwoodExplorerAs others said, after using it a few times, you will know. Also, as I heard someone mentioned on here, when it burps. Yes, it will burp when you flush it and it's full.
- cochise49ExplorerHave had four RVs that had internal tank sensors. None were still working after the first year. Limited success with all the tricks with cleaners, ice, etc. Now have one with external sensors. Only three months old so, we'll see.
- rondebExplorerWe had the exact same problem. 3/4 full and wouldn't budge. I tried everything(spent a fortune on vinegar and ice) We sat in LV for 2 winters (very hard water) so the hard water calcium built up was registering false readings. I got the gray tank cleared with hot water and vinegar, but when we got home, I decided I wanted the black reading empty. "These things bug me" I ordered
Black tank wand
It will bend into all corners of the tank. It took about 20 minutes of moving it into all corners and WAHLA tank read empty.
Definitely worth the trouble
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Feb 07, 2026
