rrupert
Jul 02, 2014Explorer
Are the 12 volt items, such as, the lights working? Did you check the 110 volt outlets? If you have 110 volts but no 12 volts you may want to check the converter, (not the inverter), to see if it has any blown fuses. Check to see if it is supplying voltage to the battery, you should see at least 13 volts at the battery terminals if it is charging.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
