2Macs's avatar
2Macs
Prodigy P3 Issues
I recently purchased a Prodigy P3 brake controller. After installing it, I have run into an issue about the brakes engaging on the TT.
I have set the P3 to 7.5 and the boost to 2 and the type to Electric. When I step on the brake, the TT brakes barely engage.
Manually applying the trailer brakes causes the TT brakes to engage, but the do little to stop the truck an trailer. I had the TT brakes adjusted by a pro at the local RV dealer. Under the old Tekonsha Envoy controller, I could apply the TT brakes manually and lock them up.
I am looking for solutions to this problem so I can get the P3 adjusted properly. I am going to spray WD40 into the TT plug to get rid of any corrosion that may be present and cause the signal from the P3 to work properly.
Any other ideas would be greatly appreciated.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
