dee74's avatar
dee74
Propane Auto Change Over Did not work
I have a propane auto change over valve did not work on my 2015 Springdale this weekend and I am not sure what happened. I went out after I could not light the stove and the indicator was red but the valve did not switch over to the full tank. I eventually was able to get the full tank going by disconnecting both tanks and letting the pressure out of the lines. Anybody experience a similar problem? Is there anything I should be looking for?
  • ktmrfs wrote:
    3 possibilities
    1) It switched, but when you opened the valves initially, you opened the second tank valve to quick and it triggered the excess flow port. once that happens, you get about enough flow for pilot lights, not much else.
    2) you DID have BOTH tank valves open right??
    3) Bad changeover valve.
    I'd put my money on (1) or (2)
    I definitely had both valves on but I may have opened one too quickly I really do not remember. I have definitely had that happen before and I noticed it right away but both tanks had propane at that time.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    3 possibilities
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
