Andrewmart
Mar 12, 2021Explorer
valhalla360 wrote:
Higher hitch weight is almost always better.
Where people get in trouble is they try to take a light duty (low payload) 1/2 ton and then get caught between keeping within the payload but above 10% hitch weight.
With a 3/4 ton, it should be able to handle a 1200lb hitch weight no problem.
5th wheels are some of the nicest towing trailers and run 20-25% hitch weight with no fancy hitches. Semi's are commonly at 50% or higher.
Unless you are having sway or other handling issues, run with it.
I haven't had any swaying problems with it but yesterday I was towing and getting pushed all around. Weather app said wind gusts were up to 25mph. I think more... My wife was in her expedition and also getting pushed around. It's the most I've felt the RV since I got the F250. I know there is nothing I could do to stop the crazy wind hitting our 33 foot long wind sail, but wondered if me being too hitch heavy contributed. Google says too heavy hitch can cause TV steering problems. It wasn't necessity swaying, it was more getting pushed around out there with each gust. In between gusts or when highway changed to head wind, I had no problems.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
