HouseApe
Oct 15, 2018Explorer
Reese Dual Cam HP frame brackets
Ordered a new set and it’s new stock. Install instructions are revT 2017.
This kit has the rivenuts in it. Holding the frame brackets onto my frame and they do not appear to bent to the full 90 (I have radius corners). Seems like 88 degrees.
I’m worried that if I bolt the brackets in and torque to 75 pounds they will pull the brackets off the bottom of the frame slightly. They are supposed to be flat to the bottom.
Then I was thinking they did this because of the rivenuts head thinkness?
What’s the groups thoughts?
