WoodGlue
Jul 19, 2013Explorer
PapPappy wrote:WoodGlue wrote:
What about having a Fantastic Fan on (exhaust setting) for part of the time?
WoodGlue
Well, where do you think that "exhaust" air comes from? You are still drawing air (and humidity) into the RV through other cracks/openings in the RV, to exhaust them.
Better to use the vents in the evening, when you don't use the A/C, but keep in mind that the whole purpose of A/C is to reduce humidity, which in turn helps to remove the heat from the air. Every time you open the door or a window, you are letting that warm humid air back into the RV, causing the A/C to work a little harder....much the way that you effect the fridge, every time you open the door to look inside.....the more the system is contained, the better it's going to work:)
Thanks for the info!
WoodGlue
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
