Today I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc. I put some water in the fresh tank (found a leak at the drain valve ar...
The pump failed to prime, therefore was not creating pressure in the system, not even air pressure. The pump relies on water to cool itself. Odd that it ran for so long... Only way to know what, if any damage, is to run it again with water.
Sounds like it worked, so I would continue to keep karma in my favour...
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 03, 2026
