Tacswa3
May 04, 2014Explorer
Rookie Mistake
Today I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc. I put some water in the fresh tank (found a leak at the drain valve ar...
TucsonJim wrote:
I don't believe you've done any damage at all to the pump. The reason it was humming was that it didn't have enough water to pump up to pressure. It was trying to pressurize the lines, and all it was drawing was air.
