Tacswa3ExplorerMay 04, 2014Rookie MistakeToday I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc. I put some water in the fresh tank (found a leak at the drain valve ar...Show More
Tacswa3ExplorerMay 04, 2014Good news, Found the manufacture spec sheet on the pump. Apparently its a dry running pump and is able to run dry without damage. Sweet
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 03, 2026
