Today I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc. I put some water in the fresh tank (found a leak at the drain valve ar...
Those pumps are of a hydrostatic design and will not overheat running dry (water is not used to cool them). Mine ran in an enclosed area for two full days and 4 years later it still works fine.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
