Tacswa3
May 04, 2014Explorer
Rookie Mistake
Today I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc. I put some water in the fresh tank (found a leak at the drain valve ar...
RRBob wrote:wa8yxm wrote:
(Water does not compress, what compresses is the air cushion in the water heater, Thus providing the back pressure needed to shut it off.. If you really need to understand why it works I can explain but ... Well, enough typing already for one post.
If that is the case, why does my pump shut off when I have the water heater by-passed?
