Today I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc. I put some water in the fresh tank (found a leak at the drain valve ar...
Most water pumps are diaphragm pumps. The water doesn't actively cool them, just passes through two check valves and the diaphragm. Now, if the water pump were an impeller design like a macerator pump, it would probably burn itself out in 20-30 seconds.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
