Hot welding does create a material to material interconnect similar to melting ice to ice. It's probably the strongest of all material to material connections. When applied properly by an experienced trained technician, it should outlast any tape or adhesive bond. But, hot welding is limited in where it can be used and does not eliminate the use of lap sealant or tape on an RV roof.
Looks nice, not sure it is any better than eternabond. Certainly more work, and the possibility of a mistake exists with this that does not with the eternabond.
Smart people always avoid like the plague being in anyplace anytime where the outside temperature is 110 degrees F and the top of your RV is at 150 degrees F or even at 20 degrees lower. Problem solved as usual by the smart people!
What happens to the "weld" if you find yourself in the South West or the Bad Lands or somewhere like that, the sun is beating down at it's strongest, the outside temperature is 110 degrees and the top of the camper is 150? Will it curl up?
That looks to be a pretty slick seal! I would have to wonder what may happen, with that heat weld method in the hands of the inexperienced? Yes, me, now having burned holes in my roof. :)
Jerry
