f150camper's avatar
f150camper
RV storage - how much room is needed?
Hi all!
I am in the process of building a shop on my property.
The plan is to be able to park a travel trailer and/or coach in there.
Total shop size is 32(w)x48(d) with a 14x14 door.
My main question is this: How much room do I need in front of the shop to be able to get a travel trailer in there? Let's say a max travel trailer length of 35ft with a 20ft tow vehicle.
I have attached a quick drawing to visualize what I am talking about.
It looks like I will have about 57' (give or take a couple feet) in front of the shop. 44' of that will be on gravel, 13' will be on asphalt.
Will this be enough room for a 35' TT or 40' Coach? I bet the Coach will be fine, but not sure about the TT.
BTW, I can't really try it out with the max length trailer, so please don't suggest that (placing cones, etc). We currently own a 21' TT, and I am sure I'll be fine getting that into the shop. I want to be able to use the shop down the road for things bigger than what we own now, or even enable any potential buyers.
Really appreciate any input!
  • For the images, you're putting in the URL of a page with the image rather than a direct link to the image itself. This might work better.
    Here's my two cents, which may not be worth the pennies:
    Maneuvering a trailer will partly depend on the tow vehicle: how tightly it can turn, and how sharp an angle you can get between it and the trailer without crunching something. With a good tow vehicle you could easily maneuver most any trailer into position with that space (well, you could provided you have some experience/skill at backing a trailer). One rather extreme example of a great vehicle for this is a standard farm tractor, which can turn very sharply if needed thanks to wheel brakes, pivoting around either of the back wheels.
    A class A coach probably could be maneuvered into that space without extreme difficulty, I suspect, though I don't speak from any sort of personal experience. A large class C would probably be tricky as they tend to have pretty terrible minimum turning circles (and I do speak from some experience there). More room would definitely make things easier. I'm assuming the width of the gravel portion is at lest somewhat to scale--that it's considerably wider than the 13' wide asphalt drive, even if not nearly as wide as the shop.
  • How in this world do I share images here? Used to work just fine, but have not done it in years.
    Any help would be appreciated!
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 26, 2025
