dodge_guy's avatar
dodge_guy
Explorer II
Jan 17, 2017
RV weights?!!!
So we were at an RV show and I was poking around a bit and started to look at the weight stickers. found some "1/2 ton towable" TT`s with dry weights starting at 8k lbs, one was 8700lbs!!! now, I`m not a weight police member at all, but come on!
Then I was looking at some class A`s. one looked real nice good layout with bunks and plenty of storage. the only problem.......1200lbs of CCC. with people alone that will be 800lbs!!! that leaves 400 lbs for stuff. now I know I pack heavier than most people, but I don`t know of any family that will only have 400lbs between clothes, food, bedding, chairs, and cooking utensils among other things. my trailer alone carries 2klbs of "stuff".
So to all new RV`ers looking to buy, look at all the weights (dry, GVWR and CCC) and don`t listen to the salesman or the smiling 1/2 ton truck sticker! If it sounds like it wont work, it most likely wont!
shop carefully!
  • I've seen plenty of 1/2 tons that will handle over 1500 lbs. of payload.
    And there are also plenty that wouldn't have enough leftover capacity for the family with 1225 lb of tongue weight, and come from the factory with receivers that won't handle it, and axle ratios that are unsuitable for pulling 10K down the road. I'm with the OP--you need to know your TV, because the manufacturers and salesmen don't have a clue in most cases.
  • What makes you think your not a member of the weight police?
    So you load the trailer and it comes in at 10,200. That's 1225 lbs. of tongue weight. I've seen plenty of 1/2 tons that will handle over 1500 lbs. of payload.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 14, 2025
