Scott_Malkinson's avatar
Apr 03, 2017
ryobi 2200w generator extended run tank
So its time to buy a generator, but I want to get one that can run a 6 gallon extended run tank by ipi industries. Ive got my eye on a ryobi 2200w generator, but I cant find any information if it can run the extended run tank without having to gravity feed it. Ipi says the tank is compatible for the ryobi, but doesnt specify if it has to be gravity fed or not. As far as I can tell, only the honda eu2000 are able to run an auxiliary tank through suction because of the internal fuel pump. Has anyone ever used this ryobi generator with an extended run tank before?
  • they will give u a 300 dollar product using 8 dollars of parts and a 8 dollar vacuum operated pulse pump
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
