ThorResidencyNe
Apr 24, 2014Explorer
You would also need to install a transmission gauge to really know if the tranny is really having an issue. If it really is running hot, then you would need to address the issue with things like an extra electric fan on the cooler, a larger cooler and/or a transmission pan with extra capacity and/or cooling fins. You can also switch to synthetic fluid which can tolerate higher heat levels. Good luck.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
